photobug wrote:
Probably a dumb question, but when using leveling blocks on duallies, do you need to block both tires? Was thinking about using a set of those new rapid jack levelers, but they're $40 a piece. If the parking spot is level front to back but tilting side to side, I'd need front and back levelers (2 for dually?)
I have a couple sets of the lego type pads, these look easier though.
Yes, always use the same number of blocks for both duallies on a side. The weight needs to be evenly supported by both tires.
I have been using the yellow leggo blocks for years with good results. Never had one break but have scuffed the edges a couple of times when they started to slide on asphalt. I can just look at the levels on the corners of the coach {24' Class C}, and know if I need one or two blocks. I have never needed to go higher than two. Driving on and off is now just a matter of feel and very easy to do.
:C
