Dutch_12078 wrote:
I don't have plastic blocks, but the 2" thick laminated wood blocks I do have typically only get used on sites that are far enough off level that the low side jacks would be nearly fully extended otherwise.
Though I had plastic blocks and used them from time to time (May still have 'em don't know) I used mostly 2x12s and the awning hook is a fansastic tool for "Retrieval"
Also if parking Jacks Down in the winter I'd use 2x12's.. The jack pads would freeze to the ground but never stuck to the 2x12s.. And after I drive off them. a gentle tap with my 8 pound sledge and the wood blocks were no longer frozen to the ground either.
