Ava
Aug 25, 2015Explorer
I carry a block for each jack made from plywood and 2x2s about 6 inches high as well as plastic base plates to spread the weight on grass or softer ground. The blocks give me more height if needed.
You should not have to lift the rig off the ground unless you are on a slope but then be careful not to raise the rear ones off the ground as you will not have any parking brakes. Good luck.
38,778 PostsLatest Activity: Jun 10, 2026
