FIRE_UP
Aug 25, 2015Explorer
zach477 wrote:
What are some Do's and Don'ts for a newbie to be aware of. What surfaces to put (or not" put them down on? Or any thing else you think of, or mistakes you've made.
zach477,
Leveling a coach, almost no matter what size/length/slides/no slides etc. sometimes, requires thought. And, sometimes, it's no brainer. I have always advocated to level your coach, using the tires and wheels, by driving up on, whatever type of lumber you carry. That could be home made ramps, blocks, stacks of plywood etc. If you do it that way, then you're not stressing various parts of the coach, by trying to make the jacks over work themselves and, possibly torqueing the frame/body etc.
Once you're "somewhat" level with your drive-on setup, then, I use the jacks to "fine tune" the leveling. And, if I've driven up on some blocks/ramps to help primary leveling operations, then I break out the blocks for the jacks. That way, they don't have to travel so far to help with the leveling and, stabilization. The farther they travel out, the more lateral movement they will have tendency to display.
And, by utilizing lumber and driving up on it, you get the stability of 6 tires on the ground and, also all four jacks too. This is just my thoughts on how it's done. Many will differ. No biggie.
Scott
38,778 PostsLatest Activity: Jun 10, 2026
