Bruce_Brown
Aug 27, 2015Moderator
First and foremost, before starting any type of leveling, get all 4 jacks on the ground. That gives your frame and house a good base of support to start with. Then always, always, always use them in pairs.
Once all 4 jacks are on the ground level the worst offender first. In other words, if your side-to-side is off the most, level that first. If it's front-to-back then do that first.
No matter what make sure you're always working them in pairs and a little at a time is also a good practice.
Lets say your driver side is low. Get all 4 jacks on the ground, then start to lift the driver side. Once you lift the driver side a little, lower the passenger side a little as well. Continue this until it's level side-to-side.
Also keep in mind sometimes sites are so out of kilter a 100% complete side-to-side - front-to-back level might not be practical. Frames WILL twist and windshields WILL pop. Want to guess how I know that. :B Yeah...when I was a Rookie I never had a leveling lesson or was smart enough to ask.
I also agree with those who do a rough level using blocks under the wheels if needed. I know lifting the front wheels off the ground isn't the end of the world - I'm still not doing it if it can be avoided. Don't ever lift the rear wheels off the ground - that's where your braking comes from.
38,778 PostsLatest Activity: Jun 10, 2026
