Big_Redneck's avatar
Big_Redneck
Leveling Jacks sticking not going all the way up
My MH has Jacks underneath. What the best lube to spray on them to stop them from sticking not going all the way up? Or what do you do if this happens?
  • If they are hydraulic jacks wipe them down with ATF (automatic transmission fluid) or hydraulic jack fluid. This lubricates the seals on the jacks.
  • WD40, run the jacks all the way extended, then spray on WD40, then retract the jacks. May have to do this a couple of times.
    If you have one that is particularly sticky you can get a scissor jack and put under it to raise it.
