When additional help is need to get the MH level ( so wheels aren't off the ground by using hydraulic jacks), would it be advisable to support both rear wheels? If you used blocks under one wheel the...
I park in the level area of the site. In over 15 years using levelers I've never parked where I've had to place blocks under the wheels. If I can not get level without raise my rear tires off the ground then I'll ask for another site. I have had the front off but Never the rear! The idea of levelers is you don't need to drive up on blocks any more.
