When additional help is need to get the MH level ( so wheels aren't off the ground by using hydraulic jacks), would it be advisable to support both rear wheels? If you used blocks under one wheel the...
On my coach by dumping the air, I have a lot of travel on the levelers where I have never lifted the tires off the ground. It would have to be some really bad parking spot for it to lift off the ground. I think I would just request a different spot. On my coach you will not find any spacers or blocks to put under tires or even under the levelers. The BigFoot pads are big, so they do not require blocks like I have seen on some coaches.
