HWH computerized Auto systems
They use a pressure switch on EACH jack that sends a signal when each jack touches the ground and just barely lifts. HWH systems will level the side/corner that shows the Yellow lights indicating THAT section needs to be lifted to level. Once that section is lifted to get the RV level, the system then extends the other jacks to just touch the ground. IF the RV is level before the system operates, all 4 jacks will extends at the same time and once each jack touches the ground and starts to lift that jack will shut down when that pressure switch is closed from the pressure. Also HWH is Bi_Axis leveling. That means 2 jacks are always going together to prevent twisting of the frame.
Powergear systems have different Auto types. The common system is the 2 front Jacks are connected thru a T and both jacks will extend to prevent twisting the front to keep from popping out a windshield. Doug
