wa8yxm
May 11, 2014Explorer III
Do the LED's work with the dimmer... Depends on the LED's and on the DIMMER
Alas, that is the best info I can give.. LED's come in different types. Some have voltage regulators, some current regulators,, Some a simple resistor, THOSE can be dimmed by most any dimmer
Dimmers work in two ways, One is a variable resistor, it wont dim LED's unless you have a whole heaping bunch of them or.. Change the resistor part (The entire thing) others are PWM Radio Frequency Interference Makers, they work with MOST leds. but not all that well with a well designed voltage regulator type.
38,769 PostsLatest Activity: Mar 29, 2026
