two_travelersExplorerJun 08, 2017Lippert/Schwentec slide lubeHave a 2015 Winnebago Vista 26. Found a utube video that showed how to lube the slide mechanism. They seemed to make it fairly easy to lube the parts, but when I pull back the rubber weather seal, the...Show More
ng2951ExplorerSep 24, 2020You can also buy a longer straw and cut it to length. The other tip is to affix the straw to a wire coat hanger that can be bent to fit.
Related ContentAdding power outlets in slide with no wiringLube slide seals?Lube for battery slideslide out seal lubeLube slide-outs?
