ng2951
Oct 07, 2020Explorer
ng2951 wrote:
Not according the Lippert video. On the video they show only lubing from outside. Then their tech says after lubing the outside coupler, "do the same procedure on the inside..." it is at 2:05 into this video.
https://youtu.be/gXw9I_DoAvI
Don't care what the Video shows...Doug
Mark wrote:No that does not sound normal to me.
I have a 2011 Holiday Rambler vacationer with Schwintech (sp?) slides. Mine squeak in and out. AND when the big slide is nearing full extention it goes really slow. When I put it in, it almost doesn't move then SLOWLY comes in about a foot before going faster. I'm afraid the motor will burn out eventually? What can I do, or is it normal? Thanks Mark
I am not sure what Doug recommends...and maybe I am misinterpreting him so let him respond with his recommendations.
My problem was occurring on retraction, but its symptoms were similar to yours. I could not get the system to close the last 6 inches because the slideout was canting. The only way I could get it to close was to pull on the extended side. No matter how many times I resynced the system it would not fully close.
I did check, and the system was square when extended every time. It was on retraction it had problems.
Before I lube any I would check and make certain the tracks are clear of debris, and that nothing has gotten wedged under the slideout (shoes, toys, etc). I would also spray the seal around the slideout as the mixture also lowered the drag of the gasket/seal.
One other thing to check is if you have a awning over the slideout make sure it is running correctly and not dragging on the slideout.
I think Doug may be right about not lubing the inside couplers. The reason why is there are only 4 couplers not 8, so lubing the inside is really superfluous. The only advantage I see to lubing both sides of the bearing and Gibb is that you are sure to get both sides. Truth is once you get the technique right you are really getting both sides of the couplers.
I would agree that lubing the rack that the gear uses to move the slideout is likely not a good idea. That rack should only need to be cleaned debris and such. Lubing it, will only attract debris and gouge the surfaces. Personally, I think that is where all the confusion on lubing the system lies. Lube the couplers yes, lube the tracks no.
That is probably why Lippert keeps the video up on lubing the couplers up on YouTube. That is the part that needs lubing.
What I can say about using the recommended CRC Power Lube with PTFE, is that I could not retract the slideout before I applied it to the couplers. Now I can retract the slideout and it does it faster too.
38,782 PostsLatest Activity: Sep 02, 2026
