DAS26miles
Jul 13, 2019Explorer II
Lithium batteries questions?
Has anyone replaced their 2 12v 100 amp flooded batteries with just 1 100amp Lithium since the 2 flooded batteries should only drop down to 50 % or 100 amps? I was thinking of starting with just one Battle Born 100hr LiFePo as I have never had my existing batteries discharge more than 70 ahr or 65%. Also, Battle Born, Precision Circuits and Progressive Dynamics said I could use my existing PD4560 (non Lithium mode) converter charger for the time being. I would need to push the charge wizard to start the charging when on shoreline power oir generator. My 300 watts of solar with a controller with Lithium mode will handle a larger portion of the charging. Only issue I can see is the engine battery and alternator as they say it should be isolated permanently to prevent damage and over charging. But I think that's with the replacement converter charger that is Lithium dedicated only and continuall produces 14.6 volts with no absorption or float.
