EMD360
Jan 27, 2022Explorer
The key words are "full advantage" The lithium will charge just fine but won't get to 14 volts. I read aboutt this before I installed the lithium in ours and upgraded the converter/charger from the original WFCO but that was a recommended change anyway.My batteries don't always get to 14 volts even with the new charger. I have a 3000 watt Samlex inverter and 360 watts solar. The battery has an internal management system that doesn't charge when the temperature is too low. So I don't worry about it. I bought the LION 105 amp batteries from Costco. The advantage for us is the size. Two fit in a Winnie 25B step compartment. Most are too long for this compartment.
38,782 PostsLatest Activity: Sep 10, 2026
