theoldwizard1
Jan 27, 2022Explorer II
Bordercollie wrote:
My question is, will a standard converter charger maintain lithium batteries and provide interior lighting same as with wet type RV batteries?
You will get a "more complete" charge and a faster charge using a charger specifically designed for LiFePO4 batteries.
Get a converter that is designed for your battery type, or maybe it is time to upgrade to an inverter/charger/automatic transfer switch. Easy to install and even easier to use.
If you plan to charge with the vehicle while driving you should use a DC-DC charger.
38,782 PostsLatest Activity: Sep 10, 2026
