wa8yxm
May 21, 2020Explorer III
Ok A series of questions. and the results
Your load tester is (I hope) a good 12 volt unit with adjustable load
If the AGM's are six volts paired. you test each pair as though it was a single 220 amp hour 12 volt. This means 660 amps most load testers max out around 400-500 so it's not the best test
If they are 12 volt.. Again you test each battery by itself.
WHY: the load tester can't pull enough current to test 'em all at once.
(Just got done doing that with mine a couple months ago by the way I can hit 450 amps but consider if it's still Green. it's Green.
38,777 PostsLatest Activity: May 24, 2026
