Gjac
May 22, 2020Explorer III
Auto parts stores will load test your batteries for free. How old are you batteries? After you fully charge your batteries what is the resting voltage reading? If less than 7 years or so I would suspect bad connections at the battery posts. Clean all the terminals first and see if that works. 6 AGM batteries even with reduced capacity should start turnover a genset.
38,777 PostsLatest Activity: May 24, 2026
