dougrainer
May 22, 2020Nomad
navigator2346 wrote:
"AGM batteries CANNOT be load tested with a standard Load Tester. You must have a Load Tester that is designed for AGM batteries."
What is the difference between a "standard" load tester and a "AGM" load tester. This is something ew to me. Seems a load is a load that doesn't know the difference between a AGM and wet cell
I should have explained further. Most people think of a Load tester as a PILE that when the Tester is started, DRAWS a LOT of amps(Heats up the coil bank and glows orange). Those went out of style 20 years ago. Load Testers now are totally electronic. They
"electrically" TEST the Battery plates. So, AGM's require a specialized Load Tester. This is per Interstate Battery Corporation. Years ago we never purchased one because the Interstate model was around $1500 and Interstate would test them for us on their regular run to the Dealership. They have dropped a lot in price. AGM's are really easy to test without a Load tester. You slow charge them for a few days and then take voltage readings. A BAD or marginal AGM will not get over 12.5 volts. An older style Load tester WILL cause a tremendous drop in voltage on a bad AGM, but will not give an accurate test for a "good" AGM. It may signal BAD when the AGM is good. There are also "different" types of AGM's, that require specific testers to use. Those testers will usually test all various types of AGM's and Lead Acid. Doug
38,777 PostsLatest Activity: May 24, 2026
