william_kearney
Jun 16, 2020Explorer
When de-winterizing I found that I have a bad water leak in the catch-basin where the hot and cold and bypass faucets are located in my 1993 Pace Arrow. The leak drained the fresh water holding tank into this plastic basin and found its way to the ground via openings around the drain valves to the ground. Question: how do I trace where the water is leaking from? Everything looks dry above this location. The pump works fine and no leaks around the clear plastic part enclosing the rubber diaphragm, and no leaks from above.
38,777 PostsLatest Activity: May 24, 2026
