JaxDad
Mar 17, 2015Explorer III
pconroy328 wrote:
I patched the small holes. Epoxy. They don't leak. But it's clear (pun intended) that there's rust accumulation inside the water tank. It's gross.
I've got bleach in there now, to tide us over Spring break and we'll bring bottled water.
Thanks!!
Bleach won't do anything but make your DW feel better. If you want to remove the rust you will need something like Iron Out or CLR, however none of those products are recommended for the inside of potable water supply, so you'd need to be very vigilant about rinsing afterwards.
38,782 PostsLatest Activity: Sep 10, 2026
