Gene_M
Oct 29, 2015Explorer
Thanks Bud, RJ, CG, and Dusty.
My steps are in the back of the coach on the curb side and the battery is in a coach compartment that is outside behind the driver's seat, there are 3 circuit protectors also in that compartment. Possible that they could be behind that, under the coach, I will look.
I will check under the hood and if nothing turns up we'll do the battery switch and listen for a solenoid in different areas. (there is a black box under the driver's seat, so maybe a quick switch/listen there would be a good/easy starting point)
38,763 PostsLatest Activity: Dec 05, 2025
