We have PW Plateau TS with the one battery in the floor left rear side under the electric actuated couch-to bed. Because you have fixed rear bed I see why the batteries as so-located. You can use a small solar panel like we do, parked on the dash and connected with clips to the plus/minus terminals to trickle charge the coach battery under the hood.Also you could probably do likewise with the battery under the drivers seat which starts the engine. The generator will of course recharge your HOUSE/engine batteries but not as fast as when you are driving and the batteries are recharged with the engine alternator. Our RV does sit around a lot in winter and the solar panels help to keep the batteries at or near peak charge up condition. I dont think the engine heat will affect your Marine type deep cell battery under the hood but you could email Pleasure-way about this as they are very helpful for new or used owners of their products.Best regards,
AL
PS weather is mild here in winter so we do not remove either battery rather we start the engine and run it for 20 minutes or so or take the rv for a run. We start the generator once a month and run it for 20 minutes or so. The engine battery should not be allowed to go flat or near flat as cell damage might occur.THe deep cell Marine battery for the coach can take more heavy discharges but should not be down to less than 20 percent--this is my opinion but others may have a different viewpoint.
