djbroughton
Dec 19, 2013Explorer
Problem solved! I have now replaced the pump and the Intellitec switch controller but could still not get the pump to work through the controller. After tracing the hot wire from the pump, I discovered a 40 amp relay sitting at the end of a pig-tail beside the other fuses on the bulkhead wall. After replacing this relay, everything works fine.
Thanks for all the suggestions.
