dougrainer
Aug 25, 2019Nomad
Being almost 20 years old, I would replace the Joystick valve body. I think HWH still sells the individual spring and poppets for each lever. But for a 20 year old system, just get the valve body. Make sure you spray liquid wrench or WD 40 on all 4 jack pivot points. Slight rust will cause swing down and retraction kick up problems. THIS will NOT be a factor on your retract problem, the valve in the valve body is this problem. Doug
PS This jack has an internal leak around the valve body poppet valve, that is why I suggest you replace the complete valve body.
This is the P/n just for the single valve kit. It uses 4
RAP1635
PLUNGER AND GUIDE KIT (FOR RETURN)
https://www.hwhcorp.com/mr551100.html
RAP1635
38,769 PostsLatest Activity: Apr 03, 2026
