Gjac
Sep 03, 2019Explorer III
lspencer wrote:If that is the case it sounds more like a seal that is sticking preventing the piston from fully retracting.You already cleaned the shaft with WD-40 clean the area were the piston goes into the cylinder with q tips to remove any dirt build up.Try fully extending the jack and spray silicone on shaft and let it dry. One of my jacks does the same thing. The last time I did this was 3 years ago and jack is still retracting. Hope this helps and you don't have to buy a new valve assy.
sorry for the delayed responce. yes it will retract all the way if you twist it back and fourth. i did it several times and each time it will twist back up.
38,769 PostsLatest Activity: Apr 03, 2026
