Bill_Hamilton
Nov 30, 2014Explorer
Drill a very small hole in the frame of the window {any window that slides}right behind the lock that prevents the window from opening. Then push a rod {drill bit or other} and unlock the sliding window. Wiggle the rod to push the catch up. Then slide the window and crawl in. When finished, put some black {assuming the frame is black} RTV in the hole to seal it up. If it happens again, you already have the hole that for all intensive purposes, no one will ever know is there.
38,766 PostsLatest Activity: Jan 10, 2026
