Ivylog
Jun 29, 2018Explorer III
trikepilot wrote:
I see from your signature that you have a tag axle 45. Do you know what length your overhang is and how high the hitch is on your rig?
Bottom of hitch is 15" off the ground and 7' back on the 42' Dynasty (it's next door) and 8.5' back on the 45' Navigator. I would say you can raise the coach atleast 4" more...19".
I got hung up trying to go into a friends driveway with the Dynasty raised up (drive tires would spin in bottom of a ditch). Took me a little while to figure what to do...blocking a road. I lowered the front all the way down and made sure the back was all the way up and it went ahead. If it had still spun I was going to increase the tag axle's airbag pressure to 100+ lbs (from 45) in the hopes that would raise it up even more.
So I'm guessing you have a Piper Tri Pacer...trikepilot?
