ncrowley
Jul 01, 2018Explorer II
If you get a diesel pusher with air bags, you can get a hitch saver from Source Engineering in Oregon. You can get it for the rear and the front if both are needed. Most folksy just need the rear. It allows the air bags to inflate to the stop in the shocks. We get about 4 inches higher in the rear. You have to hold a switch down to get it to go up, and then it goes down when you let go of the switch. We have a driveway with a dip as you get out that was causing problems. We had to fill the dip with wood and now we do not have to do that.
