enblethen
Jun 10, 2020Nomad
Corrosion on frame, close look at wiring in battery control center for signs of insulation melting, battery(ies) for heavy corrosion, undercarriage for leaks.
Look at body near roof line for signs of de-lamination, Roof for signs of sealant cracks.
Interior look for signs of water damage on ceiling.
Test all appliances, check refer on different functions.
Check tires for DOT date stamp, quite often on back side of tire. Any date code more then five years could need all new tires(about $2000 for the six)
Look for any signs of leaks from engine, transmission, shocks, differential.
Rig been sitting should have brake fluid flushed and brake linings inspected
