tropical36
Aug 06, 2018Explorer II
Gundog wrote:
I have an appointment to see a 2003 Monaco Knight 32' coach tomorrow. I have done some searches on here but did not dig up to much. Is the knight an upper or lower model. If it passes the test after looking at it I plan to have it inspected by a local RV repair shop I know the owner. This coach has 45,000 miles and has been advertised as always stored inside. I am looking for a coach with a diesel to pull a boat and other trailers I have for toys. The boat weighs 8400# so it will need to have at least a 10000Lb hitch or I will need to add one. I have driven many big trucks and have owned other motorhomes. I have a class A license I know that is not required. It seems they are asking more than the NADA guide by about 10K + but I am not real sure the NADA guide seems vague on this model.
Hopefully you won't be giving more than $20K or so for it, as you'll need some room for everything you find after the sale. Always stored inside, means that it may leak with the first real storm.
As for towing, not only will it need to have the hitch receiver specs., but most importantly, the GCWR less the GVWR should be at least 10K lbs. Usually the tranny is a deciding factor, so what transmission does it have and then look for some real specs. on it, which are sometimes hard to find.
Are ya planning on launching the boat with the Motorhome and if so, how has that worked out for you, in the past?
