ViaSteve2015
Jul 12, 2021Explorer II
I think that your budget is too low if you want to find something that doesn't need a LOT of work, and more than likely some expensive repairs or upgrades. Back in 2017 to early 2018, we started looking for used gas motorhomes in the $35,000 range which was the price range for circa 2005 motorhomes. After looking at quite a few rigs and seeing how outdated, poorly maintained and in need of many repairs, we reexamined our finances and decided to spend just about twice as much money. Consequently, we found our 2012 Bay Star which was in excellent shape and the only pressing upgrade was to replace the OEM Goodyear tires.
Yes, a gas motorhome will not have the ride of a diesel pusher. But if you are not a full timer and don't plan on trying to drive 500 to 600 miles per day, they can be an affordable way to have a nice rig. Before going that route, read up on aftermarket suspension upgrades that are popular with gas MH owners. Our rig had already been upgraded with Sumo springs, and I added a Roadmaster return center stabilizer that made a big difference in reducing the effects of passing semis.
Consider also the cost of towing a vehicle whether on a dolly or 4 down. It's an added expense with a motorhome, and you need to tow or drive a second vehicle if you want to be able to run errands and do any sight seeing.
More importantly...take your time and look at a lot of rigs. With a limited budget, you may be better off with a truck and a nice used travel trailer of fifth wheel. We owned two travel trailers over 13 years, and purchasing a good used tow vehicle and travel trailer can be a much more budget friendly way to go as the tow vehicle (most likely a pick-up truck) can serve as a daily driver/second vehicle. And, it's more affordable to upgrade either the truck or trailer. We had a 28' Sunline trailer for 10 years, and "living" in that trailer was just as comfortable our Bay Star and we had almost as much living space. The motorhome is more convenient when traveling as you can pull over into a rest area, easily use your own bathroom, access your fridge, fix lunch etc.
So, proceed slowly and explore all your options for RVing. It's better to work within your budget and have $$ to enjoy your rig once you get it.
Good luck in your search and I hope you are enjoying a rig soon!
