rk911
Dec 01, 2017Explorer
my buddy just bought a 30-ft class C gasser which he says has an 8000-lb tow rating but that's the only gasser moho I've seen that has a tow rating of more than 5000-lbs. keep in mind that, in general, the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
- the weight rating of your tow bar
- the weight rating of your hitch
this is why it's vital to know what your MH weighs as it is loaded and configure for travel before choosing a toad. Your MH will not collapse if it is overloaded but you will experience handling issues as well as longer braking distances and accelerated wear on suspension, brakes, steering, etc.
good luck.
good luck.
