Passin_Thru
Mar 18, 2018Explorer
You forget moment as the weight will be approx 60 inches behind the axle so it is 6000 lb as you take the distance in inches X the weight. This is why things break when you load a golf cart in this manner. 6k is a tremendous load to add to shock, tires and axles and it bounces too adding more wt. You probably need to buy a bigger trailer or put 15 inch wheels and tires on it.
