Artum_Snowbird
Jan 03, 2018Explorer
Sometimes it's fun to do what others do and make a success at it. Certainly moving into a winter climate can be done, but spend the time to learn what others have done to succeed first. Getting into a motorhome with hopes to save money and survive the first year in a winter environment isn't easy. Lot's to learn about shielding the inside from the outside, but it's all here if you use the search engines and learn.
Start gently, find the weak links, fix them first.. keep testing the limit and don't try to jump to far until you are sure you can survive. The failure to do it right in an RV is really expensive to fix.
38,782 PostsLatest Activity: Sep 10, 2026
