time2roll
Jan 15, 2021Nomad
Inverters don't like heated and messy engine compartments. Maybe you have enough protected space and ventilation.
3000 watts really should have 6+ batteries to drive the thing. Might get by with 4 but I can't recommend just 2.
Romex is generally fine and commonly used in RVs. Although not designed to be run in conduit so maybe just use the wire loom to protect in critical spots that might rub. Can also get marine triplex stranded wire if you want something more flexible. Custom made battery cables are available too if you are considering DIY.
https://www.genuinedealz.com/products/custom-battery-cable-marine-grade-by-the-foot
