Teleman
Jan 15, 2021Explorer
time2roll wrote:
Inverters don't like heated and messy engine compartments. Maybe you have enough protected space and ventilation.
3000 watts really should have 6+ batteries to drive the thing. Might get by with 4 but I can't recommend just 2.
Romex is generally fine and commonly used in RVs. Although not designed to be run in conduit so maybe just use the wire loom to protect in critical spots that might rub. Can also get marine triplex stranded wire if you want something more flexible. Custom made battery cables are available too if you are considering DIY.
https://www.genuinedealz.com/products/custom-battery-cable-marine-grade-by-the-foot
It's a class A so "under the hood" is isolated from the engine and very well ventilated. I don't need that much power so I'm returning it in exchange for a 2000 watt unit. Mostly it's for our coffee maker and small vacuum cleaner. TVs are 12v.
