lanerd
Mar 07, 2014Explorer II
Hope you don't mine, but I've taken the liberty to add punctuation, capitalization, and paragraph indentations to make it a little easier to read and answer your questions. No disrespect is intended.
majortwo wrote:
Hello, my wife and I are looking to buy a class A diesel. First of all, Jonny I read your article and thank you for taking the time to write it.
My question is: what brands are the best as far as fewest problems, quality of materials used? All brands make different levels of coaches...from entry level gas rigs to almost million dollar DP coaches. Is one brand better than another? Probably not, but you can get different levels of quality in each.
We like the floor plans on some of the Fleetwoods, but I have read a few negative things about them. The brands that seem to be best (from what I've read so far) are: Winneabago, Newmar and one other one that I can't remember at the moment.Tiffin?.... Country Coach?.... Monaco?.... Beaver?.... Holiday Rambler?.... Safari?
We are looking at used units because let's face it, new ones are very expensive. How important do you guys feel having a washer/dryer are?Our previous coach had a "combo" w/d and we hardly ever used it. Our current coach has a "stacked" w/d and we use it a lot.
Do most of you use them or just find they fill your holding tanks faster then you would like? Typically when using the w/d, you open the gray tank so that you don't fill the tank.
What are the most important things to look out for when shopping for a used RV? Roof,delam,rust?Yes. In addition, a record of maintenance by the previous owner really, really helps out a lot in determining how well the coach was taken care of. No record? Try to find the name of the previous owner and contact him directly.
How many hrs on a gen is a lot? Again, it depends on how well the unit was maintained. Good records showing regular maintenance...great. No records...who knows.
We are looking at RV's between 38 and 42 feet. Also, is there any advantage having an RV with tag axles other then more weight carrying capacity?A tag will provide a much smoother and better ride with less wind deflection.
Our goal is to buy in the next couple years and use it for weekend trips and one major trip per year until we retire and then be snow birds or full time RV'ers. Any advice you guys have is very welcome and appreciated. Thanks guys
