- Rich___Cheri_ExplorerAwhile back I posted about converting dead space above my '04 37C refrig to storage. I popped out the thin filler that gave me access to the empty space above the refrig and built a fold down door with double "grabber" closers to keep the door closed on hard turns. Inside I built 5 inclined ramp trays, each wide enough for a standard veggie can and one ramp for 2 side-by-side tuna cans. I added stops at the bottom corners of each ramp to stop the cans from rolling up against the door. Each ramp can hold 6 to 7 cans and as you use them the others roll down to the front. I've reserved one ramp for green beans, another for corn, etc. For the slide out wire trays in the regular pantries I cut the wire from end to end along the bottom center and inserted a thin piece of plywood the size of the opening at the top. Pushing this to the bottom and sandwiching with a similar piece on the outside bottom the baskets are now square instead of wegde shaped. I glued auto-trunk liner (gray) on the inside bottom. Much better for boxes, bottles, etc.
- bigred1cavExplorer
rolnhome wrote:
Big red 1 Cav, I could use the same username BTrp 1/4 Cav 67/68
Welcome home. CTrp 1/7 65/66 - rolnhomeExplorerBig red 1 Cav, I could use the same username BTrp 1/4 Cav 67/68
- dkingdoeExplorer
bigred1cav wrote:
With your being able to answer that question, I have one for you. The slide plastic door on the screen door goes in to a plastic dock on the frame of the screen door. Our plastic dock is broken the slide is fine, where may we purchase the plastic part that is attached to the screen door?
Thank you.
BIGRED1CAV ... maybe THIS what you are looking for? - LobstahExplorerThat may be due to the fact that GM is dropping the gas 8.1L engine...
Jim - dkingdoeExplorerHas anyone noticed that Fleetwood DID NOT manufacture any PACE ARROWS this year (2011)?
I wrote them to find out if that were true & here their response:
"The Pace Arrow is not currently in our production line and has not been since the 2010 model year. It's possible it will be brought back though, at some point, as there have been a lot of requests for it. Thanks again!"
Donna R. Roe
Sr. Administrative Specialist - bigred1cavExplorer
FreshAir wrote:
Lobstah wrote:
I'm still looking for the part of the door handle that locks the screen door in place. It has the little lever that latches over the edge of the screen door so the two doors travel together. I had an internal piece break off, and now I can't find a replacement.
Jim
Jim, The PN from Fleetwood is 354852, at least it was a year or so ago. Black flat plastic with 3 elongated screw holes and the lever mounted to it.
Thank you. - LobstahExplorerAlso...anyone else have problems with the glass in their cabinet doors rattling? My plastic retainer strips are always coming loose, so one of the things on my list today is to start to remove the doors and replace the retainers with a bead of silicon caulk. Our coaches rattle enough going down the road without adding the glass panes to the mix :)
Jim - LobstahExplorerSome time ago there was a discussion of inverters on this thread. Based on my experience this winter, I need some info.
Above my propane tank, 1st compartment right of entry steps, I have a large device with battery cable connections to it. In the past, I though this was my CONverter, used to provide 12VDC to the coach and to charge my batteries. This winter I had some batteries damaged due to power loss and freezing, and discovered that my CONverter was actually mounted in the galley, on the floor, under the bottom drawer.
Since that discovery...I'm guessing that the device above my propane tank must be an INverter. If that's the case, and someone else has the same setup, what outlets are powered by the INverter? Is it on all the time?...I don't know of any switch anywhere that controls it.
Jim
-------------------------------------------------------------------------------- - rag-ftwExplorer
kemdignam wrote:
I'm trying to replace the struts on a few of the basement doors and the part number that I pulled was Master Lift ML35-80. I cannot find that part sold anywhere. Has anyone replace the struts on their PA? Mine is a '06/36D model.
On a side note, I did pull out both TVs and replaced them with new flat panels. I just LOVE how they turned out!
Thanks,
Karen
Karen,
Here is another good link for gas struts: http://futuresalesrv.com/
I used the ML13-60. They also sell mounting hardware and may be a little more cheaper than some.
bob g
38,743 PostsLatest Activity: Aug 06, 2025
