- bricotExplorer
bricot wrote:
PaceArow wrote:
WIND SHIELD WIPERS Problem
I have an 05 Pace on a W24. Replaced the Windshield motor a couple of years ago. Since then I had the problem of wipers not turning off. Now however the wipers only work on High and the sprayer works but does not turn on the wipers. Have to time it right to turn the wipers off when they are not in the middle of windshield. I tried a new motor, and that is not the problem. I traced the wires all the way back to the motor and the only plug in the line is fine. The ground is clean and looks good. Any suggestions, I know others have had this problem, my bother in law has the exact same issue on his 04 Southwind. Would love to hear what has been done to correct this issue.
Isn't this the problem where the wiper connection inside the fuse(?) box had corrosion on it, it was posted awhile back. May be slightly different in that I have had them, like the original poster, where they just won't shut off.
Should have said connection box not fuse box, where the wires from the wiper connected. - JimExplorerRemember, Greg, some large RVs use relays along with fuses to light long strings of lights. Check for a relay not inserted fully in a socket, or for a corroded or broken wire near a relay.
- AHRMA1ExplorerNo tail lights and then some...
I have;
No tail lights
No clearance lights on the right side
No backup lights on the right side
There are 2 fuses for the tail lites, L&R, in a box in the engine comp. The fuses are good.
I do have brake and turn sig. lites and all red lites at the top in the back work.
When I take the round plug apart there are 2 contacts that are hot from the front, when the lites are turned on, but there are no wires coming from those locations in the mating half going to the rear.
The flat plug on the left has a white with black wire that is hot when the lights are turned on. It goes back and up the the left side.
Anybody got any hints?
Picture of plug is here- copy and paste into address bar.
http://s364.photobucket.com/user/speedway75/media/2013-07-30132454.jpg.html - bricotExplorer
Isn't this the problem where the wiper connection inside the fuse(?) box had corrosion on it, it was posted awhile back. May be slightly different in that I have had them, like the original poster, where they just won't shut off. - FreshAirExplorer
hammer01 wrote:
HELP!!!
I am looking for a kids football shape porch light (amber) lens that came factory on the 2004 pace arrow. I called fleetwood owner services and the replacement light that they have is a different style. All i really need is the lens.
Thanks, Jeff
For my 2005 the OEM PN was 395194 complete light asy. Fleetwood now only stocks the amber lens for it, PN 538295. $5.95. I think it is same light as on 2004.
Fleetwood 800 322-8216
http://www.fleetwoodrv.com/partsandservice/
Pat - LobstahExplorerI replaced mine with an LED light from Starbright (I think?) that I got off Amazon. LED and motion sensor. Base is larger than the original, so covered it up just fine. 2 screws and 3 wires.
Easy Peasy
Jim - Jim_BakkerExplorer
hammer01 wrote:
HELP!!!
Thanks, Jeff
Got mine from Walt's RV
Complete light only. - hammer01ExplorerHELP!!!
Thanks, Jeff - AHRMA1ExplorerThanks, I didn't realize that box was there...The fuses are good! There are left and right tail light fuses, both good. The bulbs are good too.
- FreshAirExplorerDouble post
38,749 PostsLatest Activity: Nov 26, 2019
