- Rich___Cheri_ExplorerReplaced plugs and wires. Some wires may be still good, but some will come apart due to being "cooked".
- Paul_TurpinExplorerJust wondering, did you replace the plug wires? I was thinking on replacing the plugs and wires after this season and wondering what plug wires some are going with.
Rich & Cheri' wrote:
Was having misfires and rough running at high speeds and when accelerating at higher speeds. Checked spark plugs and they were very bad. Gaps were about .065 and tips were eroded. There was evidence of spark jumping to plug collar. Installed new plugs and engine now runs great. Plugs were supposed to be good for 100,000 miles but I only had 37,000 miles. - Rich___Cheri_ExplorerWas having misfires and rough running at high speeds and when accelerating at higher speeds. Checked spark plugs and they were very bad. Gaps were about .065 and tips were eroded. There was evidence of spark jumping to plug collar. Installed new plugs and engine now runs great. Plugs were supposed to be good for 100,000 miles but I only had 37,000 miles.
- Paul_TurpinExplorerGot the samething going on. The fresh water tank selector valve is bad like you stated. To replace it is a little more than what Mel had with the city water fill. My fresh water tank selector valve is connected to the water pipes with the clamps and I don't have the tools to remove and replace them. The service department wants $100 hour to work on it. I have ben keeping my eye open for someone with the pipe clamp tool and when I find it, I'll fix it.
One thing I have been doing for now and it works but I don't know for how long is: Everytime I connect up to city water, I turn the fresh water tank valve on and off real fast.
Good luck
Paulseatec wrote:
I have a similar issue. I have 2007 pace arrow 37c and when i hook my MoHO up to city water the fresh water tank slowly fill sup. Broken Fill selector valve? - Paul_TurpinExplorerMel,
The city water valve needs replacing. There is a check valve inside that is bad or stuck. If you remove the three screws on the valve, it should pull out so you can disconnect the water line. There are several city water fill valve so take the old valve to match it. It is easy to do and don't cost much, so I would replace it than try to fix it.
PaulCathy Johansen wrote:
Problem:
When I use the water pump in my 2004 Pace Arrow, water comes spewing out of the city water fill valve.
Is there a stuck valve somewhere in the system?
Mel - seatecExplorerI have a similar issue. I have 2007 pace arrow 37c and when i hook my MoHO up to city water the fresh water tank slowly fill sup. Broken Fill selector valve?
- Cathy_JohansenExplorerProblem:
Mel - R2DillonExplorerI had to take my horns apart and clean. They are electric with a metal diaphram. Mud Daubers may build nests that block the sound and they are very sensitive to pressure.
- Jim_BakkerExplorer
PaceArow wrote:
My fog lights do not work again I have checked the fuse and the switch appears to bbe good. Any suggestions?
I seem to recall previous posts about this. My memory isn't always trustworthy, but I seem to remember that the fog lights won't illuminate unless the headlights are on. - bricotExplorer
Jachinator wrote:
Hi everyone, I just brought home a used 2005 Pace Arrow 37A. It has the Workhorse W22, and has about 8300 miles on it. I would like to know if anyone who owns one of these Pace Arrows has any recommendations on sway bars, steering stabilizers, or other items that they have installed on their Pace Arrow that really makes a difference.
I would also like to know of any problems to check for that you may have had with this Unit. Thanks for the info in advance, and look forward to learning more about my Pace Arrow. Thanks Dave
I did the Brazel's UltraPower upgrade, Safe T Trac, Trac bars... really like the results. You can read the orignal post here
http://rv.net/forum/index.cfm/fuseaction/thread/tid/17618390.cfm
38,778 PostsLatest Activity: Jun 06, 2026
