- saberExplorerAnother item I just thought of as we are getting ready to go on the road. Has anyone had a problem with the trip computer display on the instrument cluster? Mine has slowly disappeared and now only shows a random display of vertical lines.
- saberExplorerAn item of interest for all. Remember the threads concerning the dash squeaks and loose screws? There was also an item about quality control out of the PA plant and these screws. Well I finally thought it was time to check the screws and about three wee gone and the rest except for one were loose. One that fell out didn't go far--it was in the right front tire, but not far enough to cause a leak. Replace them all with larger stainless steel (which I have been swapping out a lot of screw with stainless steel) and will see how that works.
- Meme_RayExplorerCleaners:
I clean our Pace Arrow with a general all purpose cleaner and use a degreaser I found called SD-20 by Spartan in a spray can (www.spartanchemical.com) for the extra dirty portions (usually along the bottom of the rig or black streak marks). This SD-20 does a great job by foaming away the dirt. It is pretty much spray on and wipe off. I do use mico fiber shop towels which I think clean up the dirt and grime better.
I bought some of the self adhesive gutters that were suggested on this forum to put above our windshield last week. Can't wait for our first trip to get them installed and have streak free windows.
Meme - runagroundExplorerBack from Cancun.
3500+ miles round trip from Pharr, Tx. Rig held up better than expected, performed excellent, only problems were converter went out (took a spare) and rubber plug in wheel bearing cap popped (out lost a bit of oil but no damage). I'm really pleased with this rig. Lots of pushers had lots worse problems, failures, and things comming apart. - Bird_FreakExplorer III use Gel-gloss. You can get it a Home Depot or you can use any automotive polish on it with no problem. You can tell from my sig. I may not know much about paint or fiberglass.
- LtcspecExplorerSo, exactly what products do all of you use on your Pace? (not full body paint)
- MrMudstudExplorerIf your coach is fiberglass with gelcote, THEN you need/should use polish for gelcote and (NOTHING for paint like on cars) on the gelcote. Use ONLY fiberglass wax/polish/sealent or combination.
Now, if your coach is all full body paint, then any good polish will do. - dcbrewerExplorerThe only wax I have used is protect-all, on full body paint seem's to do a good job!!! 06 Pace Arrow 36 D.
- LtcspecExplorerHello Pace Owners,
Even though we still have a couple of feet of snow on the ground, I am anxious to start thinking about Spring. It states in the manual, that I should not use wax products with petroleum in them. So, what do you use on the outside of your rig? I tried a non-petroleum based liquid that camping world sells, but sure doesn't seem to do the job that a canuba wax would do. Any suggestions? I read all the labels of the products that West Marine sells and all of them have petroleum in them, as well as Auto Zone.
Thanks,
bob - bricotExplorer
EMC_Guy wrote:
Hey gang,
First I want to say thanks to all the members of this forum.
Without your posts, I would not have been aware of the many issues with the 37C MH. Other than the short awning, all of your posted trouble spots were inspected thoughroughly during my inspection.
IT took me a few days to read all 92 pages of this thread, but I finally got through it the night before pickup :D
My wife and I just purchased our first RV. We picked up a 2004 PA 37C with 15K miles from a dealer in Tampa.
We love the coach and so far no major problems.
Managed 8.3 mpg on our first trip over to Cape Canaveral this past weekend. Not bad for a nig coach like this.
I do have a few questions I'm hoping someone can answer:
1. I've killed the MAIN battery twice by accidentally leaving the key in the ACC position. I measured the current draw at 6A with the key in ACC pos. What circuits are active with key in ACC?
2. Where is the charging LED for the solar panel? I cant seem to find mine.
Usually on the ceiling A/C Vent, the solar panel is mounted to this A/C unit. Little red led that comes on when it is charging.
3. Where can I get schematics of the coach and chassis?
4. All 3 Water pump swithes are OFF but I still have water pressure. Why? The only way to eliminate water pressure is to disengage AUX batteries.
You are getting constant water pressure with the pumps off and not hooked up to a water supply through you 'City Water' connection? If no external water connection is present, when you open a faucet do you hear the pump kick on?
Boy do I need a set of schematics....
Thanks,
Ed
Live your dreams!
www.dscc.us
38,769 PostsLatest Activity: Apr 24, 2002
