- Bird_FreakExplorer IIbricot
I used a 2 ft level on the floor. I leveled the coach front to rear then turned the level side to side and set computer. When I got done the counter top was also level with no more cans rolling of the counter. - bricotExplorerWhat are you using for your 'level' spot? Which instructions are you using to recalibrate?
- Bird_FreakExplorer IIYou may need to reprogram your levelers. Very easy to do, I just did mine last week when I found the instructions on their website.
- bricotExplorer
Paul Turpin wrote:
You haven't really said what was wrong with your auto levelers. One place you can look at is www.powergearus.com They list a lot of troubleshooting ideas and maintenance tips. One thing they list is how to calibrate the auto leveler switch with the jacks.tom3249 wrote:
we own a 2004 Pace Arrow. We have approx 12,000 miles on it and we bought it new. We are happy with it and have had very little trouble. The biggest being the auto levelers don't usually work right. I have to manually do the job.
What touchpad/control unit are we running? - Paul_TurpinExplorerI had put in the 12 volts fans but everytime I turned around I had to replace them. I got two small 110 volt fans and mounted them behind the refrigerator. I don't use the ice marker so I used the ice markers 110V plug then connected it to a on/off switch mounted so it is hidden outside on the refrig vent. That way I can turn them on and off as I need to. The 110V fans really blows the air behind the refrig and out the top vent.
Have no idea what the 12V hot wires are there for. But glad to know they are there if needed. - saberExplorerPaul,
We bought the rig new and the fans were factory installed. But, I seem to remember previous entry in this forum by someone who had some fans installed at a dealer on an eraly model PA. Also, ref. my previous entry, there are also two 12V hot leads behind the trim panel above the driver's window. Still haven't come up with a good idea for them. - Paul_TurpinExplorerSaber
Did you buy your rig used or does the Pace Arrow come with the refrigerator cooling fans now as standard equipment?
Paulsaber wrote:
On our 37C there are two small cooling fans mounted behind the refrigerator that can be seen when the outside access panels are removed. They pull air from the lower vent to the upper vent. Anyone know how these are controlled? I have checked them running when the outside air temp is high when the fridge is either running or not. - R2DillonExplorerThe fans are controlled by one of climate buttons on the refrigerator.
- saberExplorerOn our 37C there are two small cooling fans mounted behind the refrigerator that can be seen when the outside access panels are removed. They pull air from the lower vent to the upper vent. Anyone know how these are controlled? I have checked them running when the outside air temp is high when the fridge is either running or not.
- Fyr_guyExplorerSaber, I have the 9702 model and went to King Controls site and saw the set up your talking about. The problem I see is that you manually have to switch sats like the Dish folks have to do and how do you know what show is on what sat?? On my tripod, the dish is set on all 3 sats and can watch and record on all 3. I haven't seen the sat to go set up but will take a look and get back to you.
38,769 PostsLatest Activity: Jul 09, 2020
