- Paul_TurpinExplorerMy bedroom slide out is acting. Bring it in the slide out works great but on the way out it jerks several times. I need to get at the slide out motor and gearing under the bed. Has anyone got to this area under the bed? Looking at it, it looks like I need to remove the bed, the wood plywood base and then the bottom of the storage which is covered with carpet. Any help would be welcome, I will start into this project next week.
- R2DillonExplorerYou can replace it. If it is a weldex, try electrical contact spray in the cable at the back of the monitor
Jim Bakker wrote:
I've had intermittent problems with my backup camera/monitor, but now it's quit for good. Replacing it seems like something I could do myself. I'd appreciate any advice or warnings from anyone who has done this. TIA.
You might need a new setup but first check the connections behind the camera on the back of the rig. They are hard to get to, mine was taped to the inside of the rear cap but came loose after working on it. I cleaned the connections, plugged the connections back together and worked.
good luck
Paul - Jim_BakkerExplorerI've had intermittent problems with my backup camera/monitor, but now it's quit for good. Replacing it seems like something I could do myself. I'd appreciate any advice or warnings from anyone who has done this. TIA.
- Fyr_guyExplorer
dkingdoe wrote:
Long time hearing from anyone, including me!!! Hope everyone had a safe winter & are looking forward to a good 'camping' spring & summer.
The question I'm about to ask may have been shared/answered before, but I need HELP!! ...
We have a old heavy CRT-TV in an over the head cabinet in the front that we are wanting to replace with a new flat screen TV. Has anyone done this & how did you mount it in the space where the old TV was so that it will ride there with the least amount of vibration? The new flat screens don't have a frame around them so we can't brace it up against the cabinet.
I welcome all suggestions & PICTURES of how to replace & secure a new TV.
Thanks in advance for you help!!!
dkingdoe, I just sent you a private message if you'd like to see my flat screen mount.
Fyr - Dennis37ExplorerI found a Samsung 32 inch that just fit into the space. I used a pedestal type mount. It will allow the TV to slide forward and tilt up/down and left/right.
It has a lock system for traveling. I also use foam supports under the TV to reduce vibrations while traveling. Four years and over 40K without a problem.
I have see others reinforce one side of the compartment and use a swing arm TV mount. - dkingdoeExplorerLong time hearing from anyone, including me!!! Hope everyone had a safe winter & are looking forward to a good 'camping' spring & summer.
Thanks in advance for you help!!! - Paul_TurpinExplorer
hammer01 wrote:
Has anyone had problems with their pace arrow discoloring? The white fiberglass is starting to show a hint of yellowing. Any suggestions to remedy this problem?
P.S. It sleeps in a climate controlled shed built into my house.
Jeff
My Pace is starting to fade on the white and thousands of small little clacks all over the white fiberglass part. The cracks are only in the gel-coat and not in the fiberglass. The storage doors painted white are good and so is all of the painted fiberglass parts . Any ideas?? - R2DillonExplorerI have not had any issue with discoloring
- hammer01ExplorerHas anyone had problems with their pace arrow discoloring? The white fiberglass is starting to show a hint of yellowing. Any suggestions to remedy this problem?
Jeff
38,782 PostsLatest Activity: Aug 23, 2026
