DSDP Don wrote:
Only you can really decide what you need and how you'll use it. From what you describe as your situation, I would buy a good quality 2-3 year diesel 3/4 or 1 ton truck and then use a smaller budget to buy a decent trailer or fifth wheel. You'll at least know you have a reliable vehicle and the worse that could happen to the trailer, that would prevent you from moving around, is that the axles fall off. Then if you find that you really like the RV lifestyle, wait awhile and step up to a nicer trailer.
I tend to agree in principle ... if OP doesn't need to move a lot I like the 5er / truck combo better.
But a 2-3 yr old diesel truck is going to cost some $$$. When I was thinking about replacing mine I was going to have to cough up at least $35k for something in the 6 yr old range.
I might prefer a V10 based MH for the lower cost / ease of maintenance on the powertrain and a cheap dingy for getting around otherwise. Two fairly simple gas engines instead of a post-2007 diesel powertrain. Of course I'm biased as that's what I'm planning to transition into. :) My $0.02
