IAMICHABOD wrote:
In my case I had a screw come loose like that and I used some JB WELD any type will do, just wad it up and push it in the hole let it dry for a bit then screw the screw in, haven't had it come loose after 5 years.
I have the same problem. The ladder was removed by a serviceman and I suspect he put the screws back with a power tool and stripped them. Can you cram the Kwikwood in with the ladder still in place? Do you put the screws back in before the epoxy has completely setup?
TIA
Bob in Houston
