Oct 15, 2014Explorer
I had a smaller loss of coolant on mine with no signs of leaks or puddling on the ground. One day, while changing oil, I saw a cracked hose clamp on the bottom radiator hose. Evidently, it only leaked when the engine was hot and it promptly evaporated off the hot engine. Replaced the clamp and the loss stopped. However, with the rate of loss you are experiencing, it's probably something worse------------but worth checking the clamps. A lot of them failed.
In fact, anyone with a V10 should probably just replace those clamps with a worm screw clamp.
![](http://i160.photobucket.com/albums/t178/427435/DSCN8280.jpg)
38,706 PostsLatest Activity: Dec 02, 2016
