supercub's avatar
supercub
Losing power while plugged into Shore ? Follow up more info
50 amp, plugged into shore power. It's 98 degrees outside, running both AC's, TV, Direct Box and frig.
In the last couple of hours, I've lost the power 5 times, after 30 seconds to a minute, it comes back on. I called the office and they're not losing power. What do you think? Is it the shore power end, or something in my motor home? Thanks
I'm on the end of a row, the camper next to me, has lost power also. His breakers are popping.
Maintenance checked my pedestal and one was 113 and the other around 119.
On my Progressive Industries EMS-LCHW 50 which has surge protection, I'm getting the following readings.
L-1 108V 8A Code EO low voltage
L-2 116V 21A Code is good.
