noleakman's avatar
noleakman
Loss of 110
I have an 06 National Sea Breeze W22 with a Xanrax Freedom 45 inverter ! I have lost all 110 power to the front and rear TVs and cable boxes! all of the other plugs have 110 and fridge and air all work! and with the inverter on the plugs have power but noon when plugged in on straight 110 with no inverter! Is there a reset button?
  • noleakman wrote:
    Yes it has a control panel!and on generator the power shows fine on all plugs except the TV and Cable box are dead front and rear!
    have you checked the GFI outlet to see if any are tripped.
  • Yes it has a control panel!and on generator the power shows fine on all plugs except the TV and Cable box are dead front and rear!
  • On your inverter itself(not your electrical panel), you will find TWO circuit breakers. One of them has tripped.
  • have you checked the pedestal power? if possible try plugging into another pedestal.
