Jackie_Treehorn
Mar 12, 2016Explorer
rgatijnet1 wrote:
Check on your converter itself and look for a popped circuit breaker.
I replaced the converter with a Best Power Boondocker. It has two fuses, both of which check out fine. More important the unit is putting out 14;6 volts to the house batteries, which is exactly what it is designed to do unless the battery voltage climbs up into the high 12s.
I did check to see as another poster suggested whether there was some breaker in the battery area under my inside steps, but the battery leads go up under the coach and I don't see where they then hook to the converter output lines. That's where I'm presuming the problem is since the batteries show only just over 11 volts in charge yet the converter is putting 14.6 volts to the line headed to the batteries.
