D_E_Bishop
Mar 13, 2016Explorer
Old-Biscuit wrote:
Find the battery pos cable...find the in-line fuse or DC circuit breaker on that pos cable (usually close to battery). It has blown or tripped (DC circuit breaker is a small box with 2 studs---most are auto resetting/some have a very small tab on side that has to be pushed to reset)
Until you find/fix that 'protective device' NO DC charge from converter to battery
X2.
I think the type of coffee maker is only incidental and the Cuisinart Grind and Brew is a very expensive non-answer to the problem as are the pod machines, especially if you don't always have hookups. There are a lot of other things in play that have to do with when and how the load is disconnected, the least of which is using a generator as it was intended to be used.
